haknslash
- Lake Martin, AL
- Moomba
- Other
All I can say is the one time I had the plug not seated I had VERY little thrust and immediately knew there was an issue. Forward momentum was not even an option lol. Water was not pouring in from just the plug not being seated (assuming you didn’t just lay on the throttle) nor will it flood if sitting still because if you remove the plug to get weeds out the water doesn’t flood the bilge. It just stays there down in the tube. What can flood the bilge though is if the rubber manhole tube blows out or you rev the engines not going anywhere for a long time with the plugs removed (think water fountain effect inside your clean out tray) or if you had the plug out and you filled ballast on the swim deck.
