Trm1765
Jetboaters Commander
- Red Wing MN
- Limited
Hello all, a quick question about the internal workings of the clean out plugs. Mine have been giving me occasional difficulties when removing the cobra locks, at times they feel jammed. I assume the plugs are working loose and putting pressure on the locks, but the locks have prevented them from blowing which is a good thing. I thought maybe the inside of the plugs might have some sand or grime inside and pulled them apart to check them out. Everything actually looks good on the inside and they appear to be working well but there is a very small amount of slimy substance on the inside. Is there suppose be some lube inside or should I clean this out?
