mdwarchichoke
- Ft Worth
- SX
Crazy question. I was on the chase of small leaks and verifying my scupper R/R was indeed water tight. I pulled the boat down the ramp and let it sit for several minutes checking to make sure I had no water issues. All passed minus a small dribble from depth finder sensor. I replaced the o-rings on the tray access ports too as they were completely flat.
But here is the question. I noticed the clean out plugs had water on top of them. I did run the engines, but did not come off the trailer. Should the clean out plugs "leak water" back up thru them. Not really a big deal right now just a quick question.
thanks
thanks
