Clean out stuck
rkmorrison
222SE
Clean outs stuck. New owner 2023 222xe. They are the kind you have to push down and turn to get out.
Stuck how? What can you move where? and where does it stop? my boat doesn't have this kind, but these answers will help others help you out.
Are you putting all of your weight behind it when you push down to turn? Until I started spraying mine down with silicon, I needed to put all 160 lbs behind it.
once you remove it coat it with bees wax so it seals better and goes in and out easier
