Coburndj63
- Limited S
Fairly new here on the forum. Ready to order a Yamaha 252 SE for next year. Initially, I'll be using on Lake Erie, but in 3 years I'll be moving to Florida. Wondering about the amount of time and cost of taking care of a boat in saltwater? I've viewed many " how to" videos on you tube, but there are many conflicting opinions which has me a bit confused. What necessary steps need to be taken after every use? Do you need to flush engines right after use or can you wait until the next day after using boat in the evening? Do you need to flush engines with salt away, or similar product, every time you flush engines? Can you just spray boat down with pressure washer after use or should you add salt away to clean off entire boat? Should you wash after every use? etc, etc!!! Thanks!
