itsdgm
- Rancho Santa Margarita, California
So here's the back story. I have an 07 AR210 that I bought in 08 with less than 20 hours on it. I live in Southern California and store my boat outside, covered, trailer jacked all the way up, drain plugs out and next to my house. To this point, the boats been more reliable than any watercraft I've ever owned.
I've always stored it (and my previous boat) with about half a tank of fuel (treated with stabil and ring free). I tried storing it with a full tank a few years ago and when the weather heated up it overflowed which resulted in slight damage to some of the graphics.
Over the winter I get in the boat about once a month to check for water inside and I fire up the engines to make sure that everything still runs. Here's a unique situation that I ran into this off season (at least as detailed as I can remember it) and what I've done so far to fix it. I'll update this as I continue to work on it.
1. Back in August I used the boat for the last time of the 2014 season. I cleaned the boat, flushed the engines and stored the boat covered for the winter.
2. September & October. Checked the boat and fired up the engines without issue.
3. Sometime in November I attempted to start the engines with no success. The engines would turn over but not fire. Initially I thought that it could be a safety switch so I exercised them. Still no luck.
4. Next attempt (probably a week later), I thought maybe the cause was a weak battery. So I used a different battery that I know was fully charged. Still, the engines wouldn't fire.
5. Over the next several weeks, I made several different attempts to start the engines. I tried disconnecting and reattaching all safety switches, bypassing my battery switch, securing all battery connections and of course changing the plugs (which all looked normal). Still it would only crank, maybe kick for half a second and not fire.
6. Next attempt. Armed with a laptop and YDS I scanned both engines, tested all injectors and COPS. Everything including voltage while attempting to start looked normal. Still no success.
At this point it seemed that the obvious remaining variable that could affect both engines was the fuel. I had suspected it all along, but only wanted to empty the tank as a last resort.
I was tempted to add five gallons of fresh fuel to the tank in an effort to "freshen up" the fuel. But I was hesitant to do that because if the fuel was bad it would leave me with 20 gallons of bad fuel instead of the estimated 13-15 that I believed to be in the tank based on my fuel log. At this point I wasn't sure what I'd be able to do with all of that bad gas.
For some reason, possibly to check my fuel gauge accuracy (or By some act of divine intervention
) I decided to lower the bow of the boat. After attempting to start again (for at least a minute)., the PORT engine FIRED UP!!!! After lowering the bow of the boat all the way on the jack the STBD engine FIRED UP also.
At this point I walked away feeling much better knowing that the engines and electrics were all good and that I know that the problem is somewhere in the fuel tank. I figured that There's probably water at the bottom of the tank and that since the fuel pumps/pickups are at the rear of the tank it explained why it wouldn't fire with the bow raised.
Next time in the boat, I removed the floor cover and took out the fuel sending unit. I lowered the bow and siphoned the fuel out, that fuel should be good so I should be able to run it in a vehicle as disposal. Then I raised the bow and siphoned again. I was expecting to see water in the last few gallons, but I didn't. All 15 gallons "looked" the same. I reinserted the fuel gauge sending unit to seal the tank back up.
So far, I have run all of the fuel through a fuel filter and used 10 of the 15 gallons in my car without any issues. One thing that I noticed while siphoning the fuel was that it appeared that the fuel pumps sit in a slight "pocket" which would aid in making sure that the boat would run until every drop of fuel was used up. This leaves me thinking that my issue is probably a bit of junk sitting in those "sumps" that the fuel pumps sit it.
So as it sits today, I'm going to pull the fuel pumps, clean the tank, clean the pumps and fuel screens and put it all back together.
I would love to get advice from anybody who's pulled a fuel pump and cleaned their tank. It looks like the fuel line connects with a special type of connection, but I haven tried to separate anything yet. Will I need any tools, or any new gaskets to reseal it? Also, what is the best safest way to flush or clean the tank?
Sorry for such a long write up, but I wanted to document this just in case somebody else has a similar issue with their boat.
Thanks in advance for any help.
