jcb1977
- Elkhart Lake, WI
- SX
I'm trying to remove the rear access panel above the cleanout ports. I have all the screws removed and loosened all the sealant. It's ready to come out except for the drain connection. I removed the hose clamp that was connecting the black drain to the white drain fitting but can't get them apart. the drain fitting will twist 360 degrees so it's not any sealant. Am I missing something? I'm ready to just cut the black tubing and replace it once I put the panel back on but wanted to check here before I do anything drastic.
