rhibman
- Other
- Other
24 foot. Aluminum hull with extra reinforced keel. Pressure tight hatches. Borg Warner transmission. Volvo Penta Tamd42wj 220 hp. Mechanical turbo charged and aftercooled engine with fresh water cooling system. Hamilton jet drive with inspection/cleanout port. Has old but operational electronics. Navy design hull with custom aluminium top, swim platform and storage compartments. Scuba tank holders. Has 3 built-in diesel fuel tanks with total capacity of 150 gl. One small built-in gasoline tank for optional kicker outboard motor. Has huge range. Two racor fuel water separators with valves. Dual group 31 batteries. Very low 500 hrs . Tubes have no leaks. Hypalon tube set is in great shape. Built like a tank. Comes with double axle 8k lb capacity aluminum trailer, new axles last year. Good tires. Can tow it safely anywhere. No corrosion on trailer, hull or jet. Just serviced with new fluids, filters, belts and impeller. Has custom cover. Has heavy duty towing bits. RHIB or rigid hull inflatable boat can be used as diving, snorkeling, tow, work or pleasure boat.
It would cost $200k in current time to build a boat like this.
Please respond with your phone number. I will not reply by email due to the scam.
email: soloinventing@yahoo.com
