jacoviii
- Independence Mo
- 255XD
Ok for all '21+ boats that are SE, XE, SD,XD.
When getting a fault that did not just clear on it's own. You may see that it leaves a red check engine light and lower RPMs. No Forward or Reverse. No steering
Common faults,
(So fix what may have happened) Sand, sticks, weeds
Now turn key on let conext boot up. Turn key off 4-5 seconds. Then back on. Do this about 5-6 times.
I have had this work for, over heating, (Xd steering stuck with a piece of drift wood) sand in the reverse bucket,
Common faults,
- Overheating fault when restarting= lowered RPMs.
- Sand in reverse bucket fault . After freeing reverse bucket the computer leaves it where you left it.=No electric F/R direction controls.
- Steering fault stick jammed or back up to the sand bar.=No Steering.
