MHarness
- North West Indiana
- Scarab
- HO Impulse
So here is what happened. Yesterday we put the boat (2015 195HO, 250hp engine w 78hrs) in the water, parked the trailer and as I was walking back to board the boat, the bilge was on pumping out water (Engine was off and I knew 100% I had both plugs in) I immediately got it back on the trailer and out of the water, pulled the drain plugs and let the boat drain. The bilge ran steady for another minute. The amount of water was substantial. This was not from rain, as I keep the plugs out and it's stored inside.
With the boat out of the water on the trailer, I cranked the engine over quickly to make sure it would start. Immediately heard a 'clunk' and then ran smooth and sounded completely normal. I turned it off only after a few seconds.
My next idea was to keep the bow hook attached to the trailer, back it back in and watch the engine compartment to see if I could determine where the leak was.
Got it back in the water and.... no leak....?!!? We cautiously had our day on the lake, boat ran great, did a few hot laps, floated at the sandbar, pulled kids on the tube, .. zero issues, (except my anxiety from the leak that would have sunk the boat had we not gotten it out of the water)
My theory:
Earlier in the week, I pulled the jet pump to inspect. Everything looked good, impeller didn't show damage, and wear ring was fine. Good amount of grease in the nose cone with zero signs of water intrusion.
I re-assembled the jet pump.
I believe what may have happened was that the splines or 'teeth' of the driveshaft were not 100% aligned with the impeller during reassembly. That 'clunk' I heard when I started it, was the splines aligning. This then caused the rubber boot to properly seal, eliminating the leak.
Do I need to pull the jet pump again to inspect the driveshaft? If my theory is correct, and water was getting in past the rubber boot connection of the impeller and driveshaft, will I need to re-grease this connection? I did read some forums on similar issues, and some were talking about hot water in the ski compartment. I did have hot water but am contributing this to water being in the bilge, (too low to cause it to turn on) under the engine getting heated, then when the boat is 'level' that water returns to the bottom of the ski locker.
We are going to the lake for our summer vacation in 2 weeks and our main entertainment is the boat.
I have time to rush in some parts for maintenance, but not sure my next best course of action.
Thanks all!
My theory:
Thanks all!
