BCat
- Scarab
- 195 G
Hello all,
I installed a set of Cobra jet fins on my scarab today. Figured I'd post some pics. I originally considered adding Thrust Vectors, and I didn't know any other options we're out there. When I found these I decided on them. I'm a believer in the KISS principle (keep it simple stupid). The fact these bolt on and don't move appealed to me. The articulating thrust vector seemed like one more thing that could break, and I saw reviews that it kicked up water on the swim platform also. These fins don't extend down as much either so my draft is still nice and shallow.
The install took a couple hours. Was a pain getting a couple of the forward bolts through the holes I drilled without hitting the internal jet nozzle. If I had to install it again I know it would only take me 30 minutes. My only concern is possible corrosion over time at the drill/bolt holes. All the hardware is stainless and if I spray it with some corrosion inhibitor now and then I think I'll be fine.
Last part is to test it on the water and see how they actually work!
