cameron.sprinkle
- Salisbury, NC
- Limited S
@Cobra Jet Steering LLC
Installed on a 21ft Yamaha 212 Limited S. Review of the Cobra Jet Ultimate AK w/Mega Fangs Plus.
First off, install was easy. I had no trouble following instructions and the pictures provided.
Above is the picture when install was completed. Looks great!
Underside of nozzle before bolt installation.
Bolt for rear of nozzle with new washers and spacers.
Underside of nozzle with fangs installed.
Above picture is of some locktight on the inside of the nozzle to help secure the bolt. I was able to do this instead of superglue because I wasn't going to put in the water for several days.
Before bolts were installed.
After bolts installed. Jeff said to install the bolts with head of the bolt on the top. But I had clearance and left it alone.
Next are some pics of the side force stabilizer and fins.
Now on to performance. I was at the coast for testing. So the conditions are with ICW currents.
The fins and fangs performed very well. Slow/no wake handling was surprisingly impressive considering the 4-6 mph current that I was in. I did not have any type of load assisting bumpers installed on my trailer. Had no trouble loading or unloading. I could control the boat well. Reverse was improved over stock. I will say it performed well with the current, but believe it would be a lot more noticeable in a lake setting. So low speed handling was great.
High speed handling is where I noticed the biggest difference. I will describe the steering not as power steering, but more of a progressive type steering. Let me explain. If anyone has driven a car that has power steering, and a car without power steering then you have experienced both worlds. The car with power steering is great at low speeds and turning while stopped. Not so much at higher speeds as you have less feel of the road. With no power steering, you hate the times you are slow or stopped but the road response is noticeably better and you can feel the road and seem to have more control at higher speeds. That’s why race cars don’t have power steering. That’s what I felt this system added to the Yamaha. You feel like you have low speed control and ease of steering, yet when you are at higher speeds you feel the steering has that feedback and thus more feel for what your boat is doing or fixing to do. The steering is still light with system, but I feel more in control because I feel what my boat is doing/fixing to do (bow walk, turns, etc.). Tracking was straight. Tighter turns. Off throttle control was amazing compared to before. I could back off the throttle and definitely control my boat even in currents and heavy, heavy chop.
To summarize my experience.
I had the the Thrust Vectors. They performed exactly as they were described and performed well at no wake speeds. Had no complaints on their performance and advertised perfectly for what they are designed to do. I just want to make that statement clear. I am not in any way, shape, or form saying anything negative about the Trust Vectors. I did want to add that the Thrust Vectors were easy to install and directions were easy to understand. I did not have to call or inquire for help on install, but I did email for some other questions and they were very responsive to my questions. None of which were time sensitive either.
Having said that, the Cobra Jet system did the same thing at no wake speeds. Where the Cobra Jet system really stands apart was anything above no wake speed. From no wake speed to full throttle increased performance was very apparent. Highly increased off throttle maneuvering, high speed maneuvering, low speed maneuvering, and straight line tracking. I do not regret changing to the cobra Jet system. It was that little bit of extra that I was looking for to make the whole boating experience more enjoyable.
I agree with several things that I have read on some of the forums. This system should be standard on these boats. Just from the safety aspect of off power control and docking control. Not to mention the increased high speed performance.
You will not go wrong with this system and will not need the money back guarantee the is offered. You will not want your money back after you use it. Customer service is amazing! Definitely goes above and beyond to make sure you are satisfied. The only other advice I will give is this. Make sure you listen to what Jeff says to do. PUT BLUE LOCK TIGHT ON EVERY BOLT AND NUT! I have checked and double checked my bolts and nuts. Non of them, I repeat, non of them have loosened. I have about 10 hrs running the system and solid as a rock.
Buy it, you won’t regret it!
