Bearsar240
- Menomonee Falls, WI
Bruce I can't find code 231.
Just incase someone else needs it.
Now to try and diagnose.
I had this code on my first trip out but mine ran fine. I tried all the reset things also with out success. I finally cleared it while trying to connect a can doo to read the codes because there wasn’t one one the screen. The directions said to disconnect port tach which was wrong for a 17. But while trying to do so and powering on the key the a few times the code cleared and I haven’t had it come back. If you’re idling rough I would suspect a spark plug or coil. I’ve since changed my plugs which I do every year and still no repeat.I need YDS 2.0. Found a guy that said he should have it next month. Anyone in WI that has it, I will gladly pay to scan for me.
