Communication Error: Check Keypad CAN
MrMelo
242X E-Series
Both batteries are new and stay on a trickle charger. Took my 2018 242x to the dealership and they said it was throwing SCU codes 166, 184, & 191. They were able to clear codes 184 and 191 but not 166. They could not get the fault to replicate and said it was throwing a “ghost code”. Does anyone have a list of what these codes represent and a potential solution to this issue? Dealership mentioned having another boat with a similar issue and they thru all new parts at it (keypad, transducer, SCU, screen). They said they called Yamaha and Yamaha said it could be corrosion in the main wiring harness and recommend replacing the entire harness ($8k+). I’m a little worried but I think it might be a simple solution…
Your house battery indicates 12.1v so you can start by checking that. Check the voltage at the battery and verify the battery is fully charged, then determine why there is a large voltage drop to your connext.
Both batteries are less than 1 year old and were both good tested prior to start. Same issue if I have 12.7v or 12.1v on both batteries. If I turn the battery switches off & then back on after running for a little bit, the problem goes away. Dealer says they see SCU code 166. I don’t see any large voltage drops & don’t know what you mean by “why there is a large voltage drop to your connext”?
Your original post says the batteries are good, but the picture displays 12.1v on the house battery which doesn't indicate a charged battery. If you check voltage at the battery terminals and it reads 12.7v and the connext display is showing 12.1v then there is a loss of voltage between the battery and the connext.
This also indicates to me that 1 of the batteries aren't fully charged. My suggestion is to check the battery with a voltmeter to see what is the actual voltage at the battery terminals.
Here is what @I_squared_r is talking about....
Depending on what type of battery you have, 12.1V under no load is 40 - 50% charge. When a lead acid battery drops below 50% SOC, you start to damage the battery and shorten its useful life the more that happens.
If your batteries are fully charged, under no load you should have over 12.4 - 12.6V. With the key on you will have some load but should be seeing more than 12.1V if your batteries have a good charge and can hold the charge.
You should pick up a battery load tester like one of these and verify your batteries are actually good under a load:
Your issue may not be a battery related issue but it would be worth verifying the batteries are still good under load..... age doesn't necessarily mean they are good. I have a battery in my car right now that is 5 years old that is fine but I have had a battery a year old that ended up with a bad cell and would not hold a charge at the levels it should.
Eliminate the simple things like battery charge and performance first. However, you could be seeing a large voltage drop if you have loose or corroded connections in your system (battery terminals, battery switches, grounds, etc.).
Here is a list of Yamaha Error Codes. They are for the Wave Runners but should be the same similar for the boats.
A 166 Code is MSLPS 2 Main Power Short/Ground Open so checking the batteries under load and then all of the main wiring connections as I suggested would be a good place to start.
IMG_4390.jpegSame issue no matter how much I charge the batteries…
Incorrect. Those error codes are solely for wave runners and have nothing to do with the 242. I went by the dealership and asked them to print out the codes…
Also, I had the batteries load tested and they tested perfectly. No corrosion around any of the terminals, all terminals are super tight, all main wiring connections are solid. ??
UPDATE [HASH=459]#1:[/HASH]
I called Yamaha directly and they mentioned that my issue might be fixed by a software update. Apparently there is a technical bulletin out (B2018-007A) for Yamaha dealers to update to version 37 or 39. I’m currently at version 31. I’m waiting for my dealership to fit me in for this update to see if that fixes the problem…
Thanks for the update. I ended up pulling out the service manual for my 275 the other day and saw the codes were different. I was going to copy the pages for you but I got side-tracked.
Hopefully the software update solves the issue. If you have had the boat since new, interesting a software issue would rear its ugly head now but you never know.
I am also having this same code. replaced house battery as it was running low. dealer said screen was shorted out and i need a new one. i said no and picked up my boat. fuel gauge always shows full and says OVR. keypad does not work but all other functions on the screen work except clock shows same time. Turning key off will not turn boat off. it will stay on indefinitely now instead of the time delay it used to have. Im going to replace the start battery as well even though it seems to be fine but i picked it up from dealer and start battery was dead. then i plan on using electrical connection corrosion spray and start checking plugs. any ideas would be greatly appreciated
Do you know if your screen is up to date? Sounds like a LOT of various electrical issues to diagnose so I’m not 100% sure where to start… With my keypad CAN issue, it turned out to be my batteries (I think). Replace your batteries with Interstate batteries only and ALWAYS keep a solar charger (or plug in battery tender) to ensure your batteries don’t go below 12.6 volts
Yes screen is up to date. Two new batteries. Took every battery connection off. Cleaned them with wire brush. No corrosion was present but cleaned and treated all connections. Charged both batteries. Disconnected every plug plug behind screen and sprayed with anti corrosion electrical plug spray and lubricated. Homed out the keypad 120 ohm can bus. It was 120. No change so far.
Just curious, but what brand of marine batteries are you running and what # version of the update is your screen running??
Two brand new marine batteries. They are wal mart brand. Version 39 on screen. Gas gauge reads full and says ovr. Keypad comm error is only fault showing. I have 12 volts too krypad but none off the buttons work. Was told it’s definitely the screen shorted by the dealer. But after seeing everything on here it makes me wonder.
I switched my Walmart batteries to interstate deep cycle marine AGM’s & haven’t had any issues. Have you tried resetting the screen? I think you flip the key on/off 6x’s. That has helped to clear a few of my erroneous errors. Good luck with your diagnosis!! That’s a lot going on. Keep us posted if you find a solution.
screen will not cut off and i tried cutting the key off and on multiple times doesnt change anything. I would just oreder a screen but im not convinced thats the issue and not sure they would take it back if that doesnt fix it. really just want to sell it as soon as i fix it as i have lost all confidence in yamaha
Loose connection at the battery switch fixed all my Communication Errors on my 2019 Yamaha 212 Limited!!
I must have knocked it loose when I was replacing the battery cover after charging the batteries.
