ToddW850
- Destin, Florida
- 242X E-Series
This Post is VERY Graphic and not for the weak. Proceed at your own risk. I do not take responsibility for anyone getting sick to their stomach after viewing this.
It pains me to make this Thread, but I wanted to pass along the information and see what questions I could get answered.
BACKGROUND:
At the beginning of October (2016), we headed out on the boat. It was me, my wife, my son, my daughter, and two of my son's friends. We rode around with no issues that morning, then proceeded to a snorkeling spot out in the Gulf of Mexico. We anchored up there, in 20 feet of water and snorkeled for a couple hours. Water was clear. Only thing would be some jellyfish. Got ready to leave and starboard engine wouldn't start. It would turn over without issue, just like normal, but wouldn't fire up. Port engine fired up no problem.
I tried all the safety switches and lanyard. Still wouldn't fire. Fuses were good too. I know my battery was good as well. I keep extra spark plugs on the boat. Pulled all the plugs. They looked normal. Replaced with new spark plugs and still would fire up.
So my plan was to pinch the cooling line and head back on one engine. Unfortunately, I didn't have anything specifically for pinching the line. I ended up using a vice grip, but it had the round clamp. So I used the END/TIP of the vice grip to pinch the middle of the cooling line. After I clamped it, it looked closed off to me! The cooling line was flat!
So we returned on one engine. Still didn't run but about 5mph back. Speedometer didn't even register. My intention was to go faster, however, it wouldn't get on plane for some reason. I know I've run it on plane on one engine last year (had fishing line caught in the impeller). Didn't have a problem getting on plane last year. Not sure if weight in the boat played a role. It was so strange, I videoed it. I can upload the video if needed to explain.
Anyway, I get back home and the engine still won't start. Turns over just fine. About 1 1/2 weeks go by before I can get the boat to my mechanic. Won't even turn over now. Port engine still fires right up. He pulls the spark plugs to do a compression check.....spark plugs are corroded. What?? The plugs are new and never ran after I installed them. So he pulls the engine and salt water has gotten into the top of my engine. The engine is now seized!
So now he's working on getting it unseized. The engine was still in such good shape, that no salt water leaked passed the pistons. No water in my oil. Dadgummit! But now he's got to replace and rebuild parts. I'm meeting him soon to see exactly what parts I am going to need and what parts he says are still good. Not gonna be cheap either. For now, he says the block is good, but will need new pistons and rings. Also has to work on the valves.
Although I felt very confident I pinched the hose correctly, there is no other explanation as to how the salt water got in there.
Curious what you guys would suggest and what anyone else has done in a similar situation.
Here are some pics he took after pulling the head off.
And for a better explanation of the vice grips...Here is a SIIMILIAR pair like I used. But I did not put the hose where the nut is here in this photo.....
I pinched the hose with this area.
Anyway, I'm going back to the bar to drown my sorrows....
BACKGROUND:
