Livewire
- Troy, AL
- Limited
I searched the threads and kind of got idea what good compression should be on mr-1's ho. So today we did a test on both motors and had roughly 119-120psi on every cylinder. Those numbers are low, but we tested on cold motors at about 35-40 degrees Fahrenheit with the throttles in neutral.
You guys think that would be good readings for the circumstances?
