Connext question
McMark
Monongahela, PA
Sometimes, when I'm in the trip screen, the average mph shows in green then will switch to white. What does this actually mean? I was guessing that maybe it turned green when I was running at my most efficient fuel burn but after experimenting with different running circumstances, I don't think that's it. Is there a manual just for connext somewhere? I have most of it figured out but I'm sure there are features that I haven't discovered yet.
I'm thinking maybe you used your joystick to select that item. You can turn the joystick to select an item and the reset it. You can reset one item or all of them.
Like @subysti said you most likely have it highlighted with the joy stick.
Ok. I'll check to see next time I'm out. Thanks guys!
Playing with mine today that's what it is, Green is highlight and then you could reset one or select all and reset.
