TheGrayt1
Hello all,
I am really close to buyiing a clean 2016 Yamaha AR190 with about 66 hours on the clock. I made about an hour trip to go look at it and water test. The boat started right up but when running it for the first 10 minutes it acted real weird. The boat would kind of hesitate and at WOT would only go 23 mph at 6200 rpm. I killed the enging to go check thge oil and inspect everything and it looked fine. After restarting it it ran perfect and never missed getting up to 40mph and 7600 rpm. The owner said that has heppened before and it is probably old gas with the stabilizer in it. No clue how old the gas is. Has anyone ever experienced this? Should I be concerned or chalk it up to old gas? Also spark plugs and oil are original I believe so it probably needs a full servicing.
Side note, I would be getting the boat and galv trailer for $17kish, is that a good deal?
