zbell305
I have a 2018 AR210 (TR-1 Engines) with ~375 hours. Salt water use weekly but always flushed religiously.
This weekend I ran to the sandbar (about 20 minutes at 5500-6000 RPMs) and had no issue. Hung for the day, packed up to leave and checked my clean outs, they were empty. Idled to the channel no problem, pissers running. I throttle it to plane and get an overheat warning on my starboard. I see the pissers running but am getting overheat, so I run back on the port engine. Sunday I put it on a rack and ran it on the hose, its pissing out of the side but no water is coming from the jet port itself, its flowing through the drain plug / grate. I only ran it for a few minutes and didnt let it the overheat trigger. Throttled it when cutting the hose and revved fine, close to sure it isnt cavitation in the impeller area.
Is this a cooling line issue? I am not sure of which lines into the block are water in or water out, but I see that one looks like it has been leaking because I see some water build up around the clasps / head.
Tried uploading a video and cant seem to. -- any help would be greatly appreciated, thank you!
