kevalbanya
I am not sure what it is called. See the picture below, there are the small notches along the bottom of the hull. I noticed the notch sit on the trailer bunk after I loaded the boat last time if I don’t load the boat perfectly straight. I had to unload the boat and load it again to make sure the the notch doesn’t sit on the bunk because I was concerned that the bunk may damage the notch because it is not strong enough to hold the boat. What to you think? Is it OK ot let the notch sit on the bunk?
My boat is 2021 AR190
