dadofral
Jetboaters Commander
- 49426 Hudsonville, MI
- X
2015 212x. Had it out today and was running fine. My some was driving and decided to try filling the ballast bags, after a couple issues we checked on the fill and the starboard side was ok but the ports side not filling and water all over in the battery compartment. Turned the bilge on and water pumping out for a bit. So first off we have that issue.
Secondly, after the bag issue we fires the boat up and lost power / cavitation on the starboard side. I checked out the clean out port and it was now blown out. Pulled it out an checked it for debris on the impeller shaft. So, what could causing this power loss above idle speed? Sorry for the long post, but wanted to give some context. Boat was running good prior to the ballast issues
