Mark Wo
I own a 2016 ar190. Love the boat and it has provided hours upon hours of fun for our family. I do have a couple of questions I have not seen answered.
1. The clean out hole. I will have to try the suggestions here to go backwards fast, shut off the motor and put in forward. Will try that this season when the boat is back in the water. My question. WE have found it easier to push the weeds to the bottom of the boat verses pulling them out the top. Has anyone ever used any kind of gadget to push the weeds out rather than pulling them out?
2. The bilge pump in my boat has pulled out of its "cradle" and I can't get it back in. The tabs all seem to be in working order I just cant get them pushed down far enough on the cradle to stay in place. So right now, the pump is kind of flopping around and the cradle and a metal screen are still attached to the boat hull. I am thinking there must be a screw holding the crale in place but I can't find it. I am assuming the screw is under the screen but I can't get the screen out. I have not put a lot of force into getting the screen off as I didn't know if I would be wrecking anything.
I am assuming I just have to pull harder to get the screen off the cradle and there will be a screw holding it in place. I don't think I have to remove the cradle to fix the issue as i bet the screen the way it is situated is what is causing me to be unable to push the pump back on the cradle. MAke sense?
So do I just use more force on the screen or am I missing something? Thanks -
Mark
Mark
