Augusto David Rodriguez
- ST. Agustine,Florida
- X
I need help, I have a 2012 Yamaha 212X, port engine crank but doesn't run, starboard it run fine.
I was yesterday at the marina, crank both engines for maybe 1 minute before put in the water.
after I put it in the water i crank both engines and they were fine, i park and shut down, then ready to leave the dock and my port engine will not start again.
Labor Day ruin!. I swap fuel lines to try to find if fuel was and issue.and No luck, just notice that port engine when disconnected wasn't pressure as much the
port engine.( maybe wasn't running as long).Also I replace the spark plugs and nada!, I swap the ECU and interchange the fuel lines and nothing.Did the fuel pumps are different ? The engines are identical!
