Cruise Assist/No Wake Mode
EndlessSummer
I'm having issues with my cruise assist and no wake mode. No wake mode would not work and the cruise assist would only work when tapping the negative switch (down) I Any one have any suggestions? I saw somewhere that if you adjust the throttle stop screw a little counter clockwise it has fixed some issues for people, anyone had any success with that? and if so where is the throttle stop screw located on the T1 engines? Thanks
Most Likely the rocker switch is bad, have you disconnected the wires checked with a meter?
NO I have not, what would be the process for that? not overly familiar with that kind of stuff. And if it is the switch gone bad where abouts do you get a new one of those.
Its probably momentry on off swich. connect a contuinity meter from the center terminial to the plus then activate the switch that way and should get momentry connection then do the same for the minus side.
ok thanks
