cupholder replacement
Eurocat
Edison, NJ
After my last trip of the year (last year), I notice one of my rear cup holders was missing. I know a ran it hard for about 20ms or so, so it probably flew away in the water. Couldn't have been while towing since I tow with the cover on and it was in place when I cleaned previous to that last trip.
So... 2 questions for you more seasoned jet boaters. Is this covered under warranty since these things are not really supposed to "fly off"? And regardless of that, where can I find a matching one? (besides at the dealer of course.)
Ty for the help.
I have a stack of the plastic ones in my garage that I would love to give you if it was feasible to get them to you. I replaced mine with metal ones which look better and are less likely to take flight. Should be fairly easy to find a replacement as they are all the same size to my knowledge. If any of yours are loose you can wrap some tape around them on the inside before putting them back into the hole, I used blue painter's tape, and that will snug them up.
I got a perfect match for my old boat at BassPro
@Johmas50 mind sharing where you got your metal ones. :)
My boat already comes with metal ones, thus I wanted to make sure they matched. Was just wondering if there were well matched alternatives aftermarket.
@RightStuff - those look like they might match close enough. I have to go "unwrap" the boat tomorrow and take a look.
Thanks.
Academy is where i bought my stainless ones
