VONCE
- Dayton, OH
Does anyone know where I could get a custom plastic sheet made? I want to remove the radio from my boat and put a panel in place of it. On the panel, I'll likely add a few rocker switches and line-level volume knobs. I did a head unit-less install in my previous boat and liked it. Everything is controlled through my iPhone and connected via Bluetooth directly into the amps. It really simplifies everything and ditching the head unit saves a little battery while in the cove. Where can I get a panel made to go in place of the current stereo mounting panel? I could use the old stereo mount as a template to have the plastic panel cut, but I don't know where to go to get the panel cut. If I tried to do it, I'd use a dremel and it wouldn't be a very clean cut.
