Dead on side of road - bad trailer hub I85 GA/AL border HELP?
Joshua Miller
Jacksonville, NC
252XE
B9CFFD90-E7B7-4D5E-BA20-3C009C4D7CAB.png A9FE658F-C5D5-4D79-963F-A9D15F29FBDA.jpeg [USERGROUP=9]@HELP[/USERGROUP] not on the water but on I-85 at the Georgia/Alabama border and I lost a trailer hub and tire. Anybody nearby that can assist?
@Joshua Miller - do you have the stock trailer that came with the boat? shorelander or MFI ?
@Scottintexas I seen his post now it is gone. He should have an MFI trailer if stock.
Moved this to its own thread for more visibility.....hope someone can help ya!
Do you have BoatUS or towboat insurance? They cover trailer issues as well. Your auto insurance policy may also cover trailering.
I’m on the phone with GEICO right now. They are going to tow us.
I would emery cloth the axle and put the new bearings on there. It should be fine. Of course I can't see everything there.
Guys I have about eight miles to a boat ramp to get the boat off and take the trailer to a shop. Am I risking too much towing it eight miles?
Go slow, but in your situation I would try it. I assume you are trying to get out of the path........
I might just unhook and drive over to the NAPA to see what they could sell you, I would choose napa over an autozone or similar because our napa's usually have more experienced people who have a clue,
not knowing what the roads are like to the boat ramps, train tracks, etc...
Absolutely go the 8 miles easy. When your trailer is in the shop have them pull all wheels and check the bearings. Don't want a repeat on the way home.
The bottom of the spindle usually takes the brunt of it .
check for a local RV or trailer store nearby they usually stock bearings call mfi for the bearing #
Emery cloth polish it out coarse medium then fine
new wheel hub
new bearings
this will get you going
its the axle with no brake? easy job on that one
or whole new axle
I 3 wheel towed home from the lake after getting hit by a car leaving Texoma one year. It was about 100 miles. We ratchet strapped the axle up to allow the single wheel on that side to carry the load. You should be fine to go that short of a distance.
Boat doesn't have to be off the trailer to fix the hub either so if the shop isn't much farther just keep going.
Good luck!
Damn...I'm usually 35 min away from that area but I'm out of the country right now or I would roll down there and help.
1 more exit down is the town of West Point Ga/Lanett AL. We go to the marine on that exit. They should have a NAPA store there. Don't know where it is since we haven't used them. Sorry not much help from here.
Are you going to Southern Harbor Marine? Thats where we go. From your map position the roads r good to there. Never mind I see they are towing you. Plenty of garages etc in that area to help you out. Good luck.
I'm back home this tomorrow (Friday) if you need any thing I may be able to help with. Shoot me a PM. I'm 45min- 1hr north of you on I-85. Will be airborne most of tonight until tomorrow till about noon.
on a lighter note, get gas in AL...It's abut 25-35 cents cheaper a gallon than in GA. We top off every time we are down there.
F9EB6C1C-24FD-492E-AEDD-BE31D2A82F50.jpeg Thanks for all the help. My situation now is I got the boat in a slip at southern harbor marina —trailer made it the eight miles. Guy at another marina gave me a POC at Tech Tire in La Grange that will be able to fix it. Right now the tire and hub assy is somewhere on the side of the interstate near the KIA plant so I’m going to look for it. I’ll have the shop replace both hubs on the front axle.
Helluva a day but thank god this happened near a lake. GEICO wasn’t able to tow it since the tower was too high.
