Depth finder for SX190
Jeff Finan
I am looking for a depth finder for our SX190. It is a 2018 and has a spot on the dash LCD screen for a one, but did not come with it. I am curious if Yamaha sells them and all i need is the transducer and wire to hook into somewhere up behind my dash. Has anyone seen these or had one installed aftermarket? And where do you get them? I just need depth due to that I run mostly in a shallow river.
@Jeff Finan I found this TRANSDUCER for a AR195 it should fit but the price is outrageous $485 and I think you might have to find a way to program the LCD display on the SX for a depth display....I installed a GPS w/Depth finder in about 1.5 hrs for half the price of the transducer. Here's a GPS INSTALL and GPS INSTALL 2 great tutorial for you if you go this route. It's simple and about half the $ plus you get a GPS to use on other waterways. Good Luck
Thank you. I like the idea of having a GPS too.
