Drift Away
- SX
Both. They dropped the ride plate and screwed it and glued it to the ride plateNice!
Is they glued in place or screwed in place?
Cool...I'm just looking for down scanning....so should be fine....@Julian I actually have 2 transducers because of the sidescanning. The port side transducer does all the down imaging, temps and scanning to port. The starboard transducer does just the starboard side scanning. I tried with just one transducer but the keel would block the sidescan and this brand was the only one to offer the splitter for 2 transducers. I had it sidescanning and down imaging up to 40mph with no problems. I can take some video next time I'm out but the boat is still shrinkwrapped........
Pretty slick looking work there. You'll love the results.After drilling my first hole in the boat below the water line, it officially passed the leak test! Haven't been able to get it out on the water yet but I flooded the bilge and not a single drop of water came through. HOORAY for 5200!!
The marine grade board I cut out to mount my transducer near the articulated keel can be cut into an angle if you decide to go that way. Trace out the transducer, get your angle, cut it, drill and/or epoxy.Just got a Simrad G07 with TotalScan this week too. Following. I don't have a flat spot anywhere on the old SX230HO to flush mount compared to the newer boats that would keep the transducer parallel to the water without some sort of angled flush mount bracket. Guess I am stuck using the standard transom mount. Going to have to keep the kids from playing on the swim ladder and accidentally kicking it.
@subysti howdid your transducer perform in that location?!? im currently having my transducer installed at that same location! can you provide some input as to the functionality of that location?Let us know how it works. I was told the extra step in front of that would create too much turbulence at an kind of speed and give bad readings. I mounted mine to the side. View attachment 52255
