Depth Finder Volume
Stephanie Jenkins
does anyone know how to turn down the Depth Finder volume (the loud beeping) on a 2018 AR-195?
It’s soo loud and drives me nuts!
Thanks in advance!
Likely the same as the 2017 boats in which case is a single piezo beeper for all warnings (engine, depth,etc) and no volume. I put two layers of black electrical tape over the beeper and it is now much more tolerable.
Don't see a way to change the alarm volume, maybe try changing the depth: Press M and T at the same time, select 1 or water depth and press M to decrease or T to increase, then press M and T at the same time should return you to the Water depth, wait 8 seconds and you should be back to the main menu.
I changed mine from 3ft to 2.5 ft. You can also temporarily silence the alarm by acknowledging it. Press M I think.
I think @Mainah makes a little mod to quieten it down. Or you could just tape it or use foam like @ttzz mentioned. You'd have to access the rear of the helm by removing the front starboard backrest/cushion.
Where is that buzzer located. I'd love to turn it down a few notches with some foam and zip ties.
On my boat (‘17 212x). It’s under the helm, was pretty easy to locate - just your standard piezo beeper.
