DieselCamel
- Punta Gorda, FL
- World Cat
- Other
Thanks, yeah it pretty uneventful most of the time..I just like your boat. Prolly awesome in the rough!
I use an MTM Foam Cannon and it works great. However I will warn you not to spray it around your cup holders, as that is when I realized they don't have their own drain tubes but rather dump right into the storage areas under the seats (what a stupid design). Also don't make the mistake of thinking the foam cannon replaces washing the vehicle. The purpose of the foam cannon is to spray foam on the vehicle and it will carry the top layer of dust, particles and grime off the surface so that it gives to a prepared "clean" surface to hand wash so you don't create fine swirl marks or scratches. It's how I keep my black truck looking clean without a ton of scratches. Just letting you know because a lot of people buy a foam cannon and then give it bad reviews because they expceted it to be a one-stop foam car wash when in reality its for pre-wash procedure.I have not heard of a foam cannon before this thread. WOW! I'm ordering mine now!!!!
Foam cannon works even better with the correct soap. I use honey dew from chemical guys.
Do you have to use a pressure washer with this setup or will a standard hose (with the fitting) work?
I've actually been thinking about that; I don't think it would be too hard to run tubing. so far drying the cup holder out is more of a pain than I thought it would be and when I get lazy and don't do it there is way too much water under the cover of the boat.@Eric Ballard - Another option for the cupholders is buying a roll of silicone tubing and running lines to where you want the water to go. Works great for me and I have cupholders over speakers. I saw that idea posted on here by someone else and can't remember who but thought I would pass it along in the spirit of this community.
