Difference between older sx230 (2003) and 2008 model
Rich Lynn
What differences will there be in these year models? Are the engines the same?
what models are we talking about?
The hull is different, in 07 they used a higher freeboard and changed the rear storage areas and added a bigger closet,
the engines are MR1's but could be either high output (HO) or non-HO,
I believe you could also have a 2 stroke option in 2003 ??
Thanks. I don't really know the model other than ar230 and sx230. I know the ar comes with wake tower usually. Don't know the other differences.
What exactly is different about the hull from the older year model to newer? Better I assume?
Sorry for the questions. I'm a newb trying to decide if I want to juco into Yamaha boat ownership.
