Difference with SVHO intercooler.
Matthew_B
AR192
Those that have done a SVHO intercooler on a AR192, how much of a difference did it make for you? I have one on the way in the mail and am pretty excited for it to show up and do the swap! Just curious what to expect.
I think it definitely helped me with heat soak. So basically I keep the power I have, not sure I gained any power. The fizzle intercooler will definitely give some gains, but I couldn’t/can’t afford it at the time.
I installed the SVHO intercooler on my SX192 a few years ago, it definitely helped with heat soak. Air temps here in AZ top out over 120* this time of year, so was looking for any help I could get. At first I just put in a Y-fitting, but a few days later added the extra pisser for optimum water flow. I also put in the Riva pump water strainer, but don’t think it made any difference.
Bummer, I was hoping it would pick up a little in MPH and help with the heat soak. Well at least my heat soak should be reduced.
