jobu2k
- Centreville, MD
Hello all.
I have searched a good bit and found a hint or two to try but haven't been able to nail down what I perceive as a problem. I was hoping someone could shed some light for me.
I got my boat this spring (2012 AR240). I've used the boat all summer without an issue on the mechanics. A couple weeks ago I was pulling a tube with one of my heavier friends on it so I was hitting the throttles a little harder than usual on the launch. I looked down and noted that the starboard engine was up close to 8k while my port engine was much lower - approx 7k. When running the two engines at the same RPM (below 7k) everything seems to be fine - no strange sounds or odd tones coming from the engine compartment. She still jumps up on plane quickly even when fully loaded.
I tried running the engines down and up again later and the port engine was still capping at 7k.
I pulled the spark plugs last week and none of them looked particularly fouled. But to be certain, I replaced the plugs and verified the gap. This past weekend I went out and checked again - same result.
I did read that the throttle can sometimes be off a little bit and I did check it this week. At WOT position, both cables were at the stops.
I also noted, when flushing the engines Saturday evening, as I finished the flush on the port engine and burped the RPM's a couple times to blow out the remaining water, there seemed to be a slight shimmy in the boat as the rpms settled back to normal. The same was not present on the starboard engine. I don't know if this is me being overly sensitive or indicative or something wrong.
Does anyone have anything else I might check for myself before I bite the bullet and take it to a dealer?
Thanks for any help you can provide.
Steve
P.S. This is my first post on this board and I just created the profile. I apologize for the stock pic - didn't have any personal ones available to me at work
Steve
