I have boated Lake Erie before with this hull (sx230) and its fine. IF you have a southerly wind.Hi all,
Going to pick up a 2008 AR230. Looks extremely clean, only 150 hours total. Anything I should look out for, or be aware of, on the water test? I previously have had 23-27' I-O's so I understand this will be a big change. Any suggestions? Mainly plan to boat in lake erie.
Those are the Blacktip mats which are a fair amount cheaper than the seadek. You might to a search on here to see what others have said about them since I don't have any experience with that brand. I believe suke had them on his old boat. If they're comparable quality to seadek, they're a steal, the seadek cost 4 times that.I just added this to my shopping cart. Thought about doing it in orange.
Yamaha Jet Boat Interior Mat Kit AR230 HO 2007 2008 2009/SR 230 HO 2007 Foot Pad | eBay
2007 AR230 HO. 2008 AR230 HO. 2009 AR230 HO. 2007 SR230 HO. 2007 SX230 HO. 2008 SX230 HO. Simply peel the backing off - press the mats into place and they are ready to go. This is an easy afternoon job and makes a world of difference on how your boat looks.www.ebay.com
Looks like a nice clean boat! I did see the plastic scupper in the pics. You need to address that; search in the forum to get background on scupper valves.Awesome news guys, thanks for the scupper insight, will check out asap.
Ive been searching the forum for modifications. Apparently there is nothing to do for power increase, right? I saw some people talking about removing the ribbon but I think that was for the older model boats?
We're going to replace the radio, speakers, and dash.
If you are trailering, I'd say you are OK to hold off on those. If you are wet-slipping her, you definitely want bilge that is driven by a float switch.You should strongly consider a second bilge pump and high water alarm
go for seadeck - check out the mat sets at jetboatpilot.comI just added this to my shopping cart. Thought about doing it in orange.
Stereo upgrade -- > Here’s my install thread: https://jetboaters.net/threads/2007-sx-230-stereo-upgrade.8206/Awesome news guys, thanks for the scupper insight, will check out asap.
I used this thread as a reference. You can see my install if you scroll thru it.Awesome guys thank you! Has anyone replaced the rocker switch covers? Are they contura II or III's ?
