Chatt_Jetsetter
- Chaparral
- VRX
Updated 5/21/21: Stabilizer/spreader bar sorted out, done with sunshade...under $150, takes 2 mins to setup. See google doc below.
I made an extended sunshade canopy for my Vortex. Total cost (before tax) is right around $139.
Alright...I think I have this sorted out. It's not perfect, but it works really well, is stable, and super quick to setup. I went ahead and wrote up a description of what I've done and the materials I've used. Everything is working great at the moment. Note that with the sunshade in place you might not be able to stand up completely on the back of the boat. I'm 6'4" and I can sit under it, and I can get out of the water onto the swim deck easily but you have to duck when going back into the boat. I haven't measured the height clearance from the swimdeck to the sunshade.
docs.google.com
DIY Sunshade
DIY Sunshade/Bimini Extension The whole setup is (2) 5’ EMT conduit poles and (1) PVC spreader pole, the sunshade, (6) carabiners, (2) CamJams, and (2) T-connectors. Takes less than 5 mins to set up or take down. This will fit perfectly for a Chaparral Vortex 203. Since other boats are dif...
