- Royal, AR
- SX
According to CARB numbers;
In 2008 the 1052cc 8YMXM1.054HA used in personal watercraft was rated at 104.5 KW (140 BHP).
In 2007 the 1052cc 7YMXM1.054GA used in personal watercraft and jet boats was rated at 104.5 KW (140 BHP)
You can view the certifications at http://www.arb.ca.gov/msprog/offroad/cert/cert_mfr.php
For the 2007 to 2011 period the EPA listed two 1052 cc engine families 4YMXM1.054GA and 8YMXM1.054HA at 99.8 KW (134 BHP) and 103 KW (138 BHP) 2007-2011 MYs (Zip)
The 2006 SX230 owners manual specifies the non-HO as having 998 cc engines producing 140 HP @ 10,000 RPM and the HO as having 1052 cc engines producing 160 HP @ 10,000 RPM. The 2007 and 2008 SX230 owners manuals document the same 160 HP engines. The 2009 manual does not document horsepower.
The 2008 SX230 owners manual specifies it as having 1052 cc engines producing 110 HP @ 8,000 RPM.
Interestingly the 2006 SX230 manual specifies the non-HO prop pitch as Port 16.3° / Starboard 17.3° and the HO prop pitch as Port 18.1° / Starboard 15.1°.
The 2007 & 2008 230 manuals specify the all-HO SX/SR prop pitch as Port 16.3° / Starboard 17.3° and the all-HO AR prop pitch as Port 18.1° / Starboard 15.1°.
The 2009 230 manuals specify the prop pitch for both the SX, AR, Limited and Limited S as Port 18.1° / Starboard 15.1°.
Checking parts diagrams I did not find differing impeller parts for the SX and AR models. Part number 6P6-R1321-10-00 was specified for everything from a 2005 HO to a 2009 while 68N-R1321-10-00 was specified for 2003 to 2006 models with the 998 cc non-HO engines. I wonder if the pitches quoted in the manual are misprints or if 2007 and 2008 SX230s really received lower pitched impellers. I may have to pull my impellers again and check the part number.
The 2008 SX210 manual specifies as single prop pitch of 16.5° and the parts diagrams only specify an impeller for the starboard side.
@buckbuck noticed that his 2008 212X engines have stickers that state "Advertised Power: 104.5 KW" which is 140 HP my 2007 SX230 has the same stickers. My stickers specify the engine as belonging to the 7YMXM1.054GA family. My engine serial numbers are 1016279 starboard and 1016280 port with a model number of JF110CN. I wonder what the stickers on 2008 and 2009 models say?
Does anyone know what the difference is between the 2007 and before GA engine family and the HA engine family in 2008 and later?
My 2007 SX230 tops out around 46 mph. I have read of several others that top out at 46.
@Speedling, do you have any thoughts on the pitch difference?
Almost in the words of Forest Gump, that is all I know about that. I hope that others will have info to help us better understand the mystery of the MR1 engine.
