does anyone know the stereo and speaker specs on a2018 ar240?
jonas riccio
I have a 17 so they should be close but they usually come with just the 4 inboat speakers which pretty much suck....and you need to crank them to hear anything.
Most of us swap them out for Polk, JL or Wetsounds and add an amp and sub.
What are you looking at doing?
If you search the audio section you will see plenty of inspiration
Hard to find any specs.... I can probably ballpark though. Headunit is 18x4 RMS. Speakers are 30-40watts RMS with efficiency around 87dB.
By those specs you can see why you might need to upgrade them...asap,lol
We are going to replace the 4 stock speakers with 300 watt led with with covers and Les remotes and adding 2 300 watt black ones in pods on the tower.. along with a 6 channel amp
Nice...what kind of speaker handles 300 watts?
What brand are they...same band for the amp?
