Drain Plug
n1111z
Cape Coral, Florida
242 Limited S E-Series
Could somebody please point me to a good metal drain plug to replace the cheap plastic one on a 2018 242LS. Thanks
So I will start by saying I don’t have these, but have seen others on the forum say they have switched them out, and they look very similar to what is being used on the 2021 models.
Boat drain plug - ebay
Here is the exact plug I have that came with my 2021 AR195. I have two, and one was poorly installed causing a "pinch" when I tried to loosen it. Instead of hauling the boat an hour and a half back to the marina for warranty work, I just did it myself. Fits and looks perfect.
The drain plug hole on the 2015 and newer boats for the 240-242 series is built into the main casting that the keel attaches to. Cannot change out the "Hole Fitting" but might be able to use that plug. Threads look similar??
I think that plug isn't removable from the housing?
