BigBlueJeep
- SW Florida
- FSH Sport
Hi everyone, hoping to tap into the collective wisdom here. I bought a 2016 FSH 190 about 2 months ago and slowly figuring it out. I’ve read the Owner’s Manual, I have the Service Manual, and tried to research, but still have some questions about the inside drain plugs.
There are 3 plugs in the attached pics: #1 is the engine compartment, and #2 and #3 are in the ‘head’ area (storage area behind the helm). Questions are:
Q1 - When you’re running the boat do you keep all 3 plugs closed?
The previous owner told me to keep #3 closed but #2 open, obviously keep #1 closed. Is that correct?
Q2 - What’s the difference between #2 and [HASH=3560]#3?[/HASH]
Q3 - Where do all these drain to?
I assume there’s an area under the boat and engine compartment, and on top of the haul. I also assume this area drains to the 2 rear drain plugs but wanted to check.
Appreciate the info, thanks for the help. Great forum, learned so much (leaks, gel coat, G2 bimini …) already.
