treeskier
Jetboaters Commander
- Ocean City, MD
- 275SE
I am not sure if this belongs here or in the LS2000 2 stroke section but as far as I know the reverse gates function essentially the same on all of the Yamahas.
My LS2000 continues to move (considerably) while in neutral. I am assuming that since the engines are cooled by the pumps moving water form outside the boat through the engines that some degree of movement is normal since the open cooling system requires the impellers to spin in order to circulate cooling water.
I have had the boat 2 full seasons and have become quite proficient at maneuvering the boat at slow speeds with the boat in neutral (finless). I can even walk the boat sideways to dock. The trouble comes in when I need to pull into a slip head on and while bumping the boat into reverse will slow my forward momentum it often comes down to a sequence of: slow down as much as possible; bump boat into reverse and back to neutral; switch off engines at the keys; grab the dock or piling to stop. Add current or a little wind and it can be an adventure.
Could my reverse gates be misadjusted and how would I know? This cant be the way those of you that have the 4 stroke boats that weigh twice as much do it.
Any help is appreciated.
