bonehunts
- 242 Limited E-Series
I'm back at the lake trying to track down the issue on my 2016 242 LSE-Series. (NOTE THAT I just turned on the Parallel switch and the alarm disappeared but came back after 5 minutes...what in the world does this mean???)
Last week I had the error and turned my steering wheel hard to the right and re-started and the error went away and rode the lake the majority of the day without issue. That night, went back out to start it and the same alarm was on. I couldn't make it go away by turning the wheel right/left.
Symptoms:
Symptoms:
- Throttle is non-responsive.
- Buckets move easily by hand in manual override from the servo.
- I swapped batteries with a new one to see if I had a voltage issue.
- I've cycled it up to 8 times.
- I've checked fuses
- Wet Sounds amp also flashes red when alarm is on
