Madman
- Sun Prairie, WI
- 252SD
I bought a new ‘25 252SD and went the SD model because it was equipped with the DRIVE system. The hope was that the advanced steering system would make low speed maneuvering easier for new drivers and make them comfortable with taking the boat out on their own.
So the problem I’ve run into is a feature called Neutral Steering Assist. As long as the boat is in gear, it responds as you’d expect. Turn the wheel right the boat turns right. But soon as you shift into neutral, the controls are reversed. Even idling in neutral, if I turn the wheel right, the bow swings left, which is not what you’d expect.
On my ‘10 242, whenever I sitting in neutral and idling, the position of the steering wheel had no effect and the boat just sat there. If I was slowing down as I was coming up to the dock and shifted into neutral, the boat would pretty much maintain its heading and turning the steering wheel had no effect.
The issue is the same when using the paddles, too. Turn the wheel slightly right and squeeze paddle, the boat moves forward and turns right. Release the paddle and the boat immediately changes directions.
I’ve read through the manual and there is one sentence that tells you how to turn it off, but doesn’t explain what it is. I’ve been trying to turn it off. I’ve tried doing a system reset by disconnecting the batteries X3. While that fixed the issue was having with the depth finder, the boat continues to respond the same way.
Has anyone experienced this and/or found a solution?
