Hoppy
- North Platte, Nebraska
- LX
So when I pulled my under warranty SBT engine (installed by the previous owners shop) on my new to me 2005 AR210 two stroke I figured I had better check the feel of the carrier and jet pump bearings while I had the motor out. Naturally something in the bearings did not feel right turning it by hand so I pulled the carrier bearings to find that the driveshaft is misaligned, off-center, and in a bind.
I plan on cleaning up the corrosion between the jet pump parts and reassembling it to see if the driveshaft is more centered when I am done. If cleaning the corrosion between parts dose not center up the driveshaft properly am I correct in thinking the jet pump transom plate needs to be re shimmed at the mounting bolts like it is now just with the driveshaft centered when I am done?
Second question...
In the center of my carrier bearing coupler there is a loose rivet that seems to be a path for water to enter the boat by following the driveshaft splines (there were no O-rings in the carrier bearing coupler to seal the driveshaft splines as the parts diagram shows) and threw the rivet hole. I don't see any other couplers online with a rivet hole in them when I search the part number is this something someone added at some time for some reason? there also seems to be cracks radiation out from the hole that don't look right. Should I buy a new coupler? Thanks for all the help in advance
Second question...
