R502
- Scarab
- HO Impulse
Is there a preferred method of enabling drown mode on these boats? The throttle lever is interlocked in neutral with the forward/reverse lever, and the ignition key contacts are disabled while the mechanical control is in forward as well. It doesn't seem achievable with the throttle/direction controls.
Everything I read from BRP shows the Seadoo throttle lever enabling drown mode when it is maxed out and you turn the motor over. The Throttle Accelerator Sensor is not accessible from the boat controls to max it out when turning it over either. Since this is an input to the ECM, how does a guy enable drown mode? Am I stuck unplugging the injectors and coils as the only way to turn the motor over without flooding it with fuel or firing the plugs?
