KXCam22
- Kamloops BC
All of use crazy glue in some form. Although it dries fast it never seems to dry fast enough. You can buy accelerants but you never have some around when you need it. What works instead? Eye glass cleaner (or I am sure water). Spray some liquid eye glass cleaner on the applied glue and hold it tight for 10sec. I am gluing some crown molding in my kitchen and it makes an unbreakable joint in about 15 seconds. Hope this helps someone. Cam.
Ps apparenly water or alchohol will work. I never got to try a weak mix as the glass cleaner was so effective.
