BlkGS
- Melbourne, FL
- SX
Thinking through my wiring, and need i put.
I have an acr, and an existing 1/2/1+2 battery switch. Will be running 3 batteries, a pair of deep cycles in paralelle for house loads and a standard starting battery. As i see it, with my existing switch if i connect both the engine and house loads to it, the whole battery system till be used for both loads.
So i have two options, loo,ing for advice
1) Buy more stuff - in this case a dual path battery switch. This will separate the house and engine loads
2) Connect the engine load directly to the engine battery, and o ly use the switch on the house side. Since the engines are switched by the keys up front, there is no real need for them to have a bTattery turn off switch, all the load im concerned with is on the house side.
Obviously the dual path switch is the "better" option, but im not seeing what it gains me, so its spending money for no reason.
