DVSR Questions
Benny Sibbitt
Jetboaters Commander
Winter Garden, FL
I had all battery switched to the off position
battery charger on charging the batteries
While the batteries were charging I notice the DVSR relay was on – Red light was on and the bilge pump would cycle on and off every 2 min
So I disconnected the ground wire of the DVSR relay from the battery and plugged in the charger again – pump stayed off this time – works!
With all switches to the off position and charger not connected the pump is off?
2015 242ls
Dual bank battery charger
Is this normal?
Dealer installed
It is normal but not working correctly for a duel bank charger. You need to modify the dsvr relay to only work with ignition power it relatively easy. Trying to find the link.... but i am sure someone gonna chime in
I did it last week took me 15 minutes or so after locating the wires
Strange that your bilge would run with the switches off.....
@Julian that's what I was thinking......
I think I am going to put in a cut off switch for the DVSR, I do believe the only time time I need it off is when I'm charging the battery
I ran the charger cord to swim deck storage compartment and put a port plug, thinking of putting the switch next to the port charger plug
https://www.amazon.com/gp/product/B009ANV81S/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Now I don't have to climb in the boat to plug in power and don't have to remove the cover entirely
