E reverse module error
tim maneval
Scarab
I replaced my battery and now get the e reverse module error. I think the code is 4010. So I bought 4 relays and changed them. I still get the error. Any idea how to reset?
That error can be related to many symptoms sadly. Does your bucket actually move fully up and down with controls? Check. Some people have had the arm that controls it bend.
Is your new battery actually good? That's another common thing. Did you perform a load test on it?
Start with those.
The power for the electronic reverse module comes directly from the battery, mine via a 30-amp breaker. Make sure the power lead is connected to the battery and the breaker is not tripped. I recently had to replace the module due to the battery switch breaking and preventing the battery from charging. The voltage got really low and it fried the module. The new module came with the attached instructions. I purchased the B.U.D.S powerpack software a couple of years ago so I was able to diagnose the broken module, clear the fault codes, and install the new module.
