natiAR230
- Bellevue KY
New 2007 AR230 owner, this forum has a been an amazing resource and wanted to ask a few question to see what others thought of an issue I possibly may be having. So I recently changed the plugs and oil, the oil was a little over filled in both engines but was not in the air filter. I did notice a smell of gas from the oil which I know is not normal. I haven't had any issues and have been monitoring the oil level the past week and haven't noticed any significant changes, but there is a faint smell of gas in the new oil. A few questions.
1. Is it normal to have some gas go into the oil from running at idle? Or possibly from rings (engine has 250hrs)
2. What are the chances I would be having the same issue on both engines at the same time (gas smell is in both oil)
3. I ordered Yamaha ring free additive to run through and see if it helps at all and other additives I should try?
4. Should I be looking for any symptoms of a bad ECU or bad injector?
The engines have been running fine 10k rpms and about 50 mph. Being new to the boat I don't know if it has been using any additional gas. Any help or ideas is appreciated.
